Multifunction DAQ
DAQexpress RTSI error
I am setting up a  data acquisition of analog inputs using DAQexpress.
I have multiple PCI-6154 and one PCIe-6323 boards in computer.
All are connected with an RTSI cable and registered with MAX.
When I setup an acquisition including the PCIe 6323 and PCI-6154 I get a no means of  synchronization error .
Acquisitions with multiple PCI-6154 are OK.
Are the two boards RTSI compatible or am I missing something?
(1,355 Views)
Maybe you can try to refer to this tutorials for M series PCI multi-device synchronization, it mentioned about 10 MHz is a more stable clock frequency to route between devices:
M Series Synchronization with LabVIEW and NI-DAQmx
(1,290 Views)
