Multifunction DAQ
DAQExpress missing hardware
I can't use my NI device in DAQExpress.
I have recently installed DAQExpress (version 5.1) and after clicking “Add hardware” on SystemDesigner, it showed my “NI USB-9215A (BNC)” under “MISSING SYSTEMDESIGNER SUPPORT” with the action “Install NI-DAQmx 20.1”, witch I did (I had an earlier DAQmx version). But after the installation and restarting the PC, it still shows the same thing! And now if I click the Install action, the NI Package Manager shows up with “No operation to be performed.”
I know there is a similar post called Install problems on PXIe hardware, but the DAQExpress online manual lists my device as supported (see this page).
I am using Windows 10 and this device is connected to my PC through NI USB-9162 USB Carrier. I have used it with LabVIEW 2019 without any problem and I can test it in NI MAX. My LabVIEW license has expired and I just need a simple application to get analog waveform charts that can be manipulated (like zooming in, witch can't be done in NI MAX DAQmx Tasks).
(2,071 Views)
Hi Pedro
I have the same problem as you. Did you ever find a solution?
I'm trying to use DAQExpress with an NI USB-9162 Carrier and an NI-9211A thermocouple input module. I suspect the USB Carrier isn't supported by DAQExpress but I can't find a definite answer to this.
(1,949 Views)
Guys, best to post this under DAQExpress board for better visibility to relevant users.
https://forums.ni.com/t5/DAQExpress/bd-p/1017
Santhosh
Soliton Technologies
(1,939 Views)
