Multifunction DAQ
DAQExpress calling MATLAB
I have started to work with NI DAQExpress 4.1 to record time histories of accelerometers with cDAQ-9178 and 9215 modules. These data are postprocessed with MATLAB. DAQExpress 4.1 provides the new interface to MATLAB. Unfortunately, I get the error "MATLAB could not be opened", when I am trying to open the selected MATLAB-function from inside DAQExpress. I did not found any configuration entry where the path to MATLAB can be defined. How can I fix the problem?
Thanks in advance,
Jan
(2,153 Views)
Hello Jan,
Is it first time you use MATLAB through NI DAQExpress?
Have you installed Data Acquisition Toolbox?
__________________________________________
The best way to thank, is to give KUDOS
(2,028 Views)
