Multifunction DAQ
Problem Importing DAQ Confg after Reseting NI MAX Database File
After a power loss over the weekend, I was forced to reset my NI MAX Database File. I used the recommended procedure outlined here:
How to Fix or Reset the NI Measurement and Automation Explorer Database File
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8awSAC&l=en-US
Prior to resetting the DB, I made sure I had a saved copy of the configuration (saved as an INI file). However, following reset and reboot of my system, I'm not able to import the saved file. It just displays "no importable data" (see attached screen shots). I've tried other previously working config files, none are able to be imported.
I'm using NI-MAX 19.1 and NI-DAQmx 19.1
(2,073 Views)
Hello TestGuy85,
Try a force reinstall of NI MAX.
__________________________________________
The best way to thank, is to give KUDOS
(1,933 Views)
