Multifunction DAQ
DAQ6221- Generate Sinewave Output
Dear All
I try to generate a sinewave output with the DAQ6221.
I use the example contgen-intclk from the CVI examples.
If i set the frequency on 1kHz and the samplerate on 1000 then i get an error message:
"DAQmx error"
Statuscode -200018
Can somebody help me?
Is there a limit for these values?
thanks
(3,227 Views)
Hi Blias,
Do you mean with samplerate the samples per buffer?
If it is so, look in the specification of your devise, you will see that you have a Max. Output rate from 833kS/s.
Your settings generate an Output rate from 1000kS/s (1000S at 1 kHz).
So please increase your Frequency or your samples per Buffer.
Regards Jakob
(3,192 Views)
Thanks for your answer. It was very helpfull.
Blias
(3,157 Views)
