 Blias
			Blias
			06-17-2008 06:32 AM
06-23-2008 02:31 AM
Hi Blias,
Do you mean
with samplerate the samples per buffer?
If it is so, look in the specification
of your devise, you will see that you have a Max. Output rate from 833kS/s.
Your
settings generate an Output rate from 1000kS/s (1000S at 1 kHz).
So please increase
your Frequency or your samples per Buffer.
Regards Jakob
06-30-2008 09:12 AM
Thanks for your answer. It was very helpfull.
Blias
