Multifunction DAQ
DAQ task
Can one Task create two  channel?because i have two kinds of channel to be used in my application.One is the differential.The other is NRSE,So i use following step: 1.create task first DAQmxCreateTask("ADTask",&mTaskHandle[ADTASK] 2.create differential channel:DAQmxCreateAIVoltageChan(mTaskHandle[ADTASK],"dev1/ai0",DAQmx_Val_Diff,"ReadVoltage",,RangeMin
,RangeMax,DAQmx_Val_Volts,NULL),3Create NRSE channel DAQmxCreateAIVoltageChan(mTaskHandle[ADTASK],"dev1/ai1",DAQmx_Val_NRSE"ReadVoltage",,RangeMin
if i do like that,Can the task work normal?
(3,253 Views)
If all channels are using the same A/D converter it will work. You need to configure all analog in channels to be in the same task.
If the channels you wish to measure are on separate ADC's you need to have several tasks.
Hope it helps.
Pelle S
Account Manager
National Instruments Sweden
(3,244 Views)
