05-23-2007 06:13 AM
05-24-2007
04:18 PM
- last edited on
05-05-2025
01:03 PM
by
Content Cleaner
Hello Peeter,
Thank you for posting to the Discussion Forums. I see that you are trying to use your USB-6009 with LabWindows/CVI 8.0 and you want to use DAQ events and occurances. You will not be able to do that with our USB devices. USB devices are supported by our DAQmx driver only and DAQmx no longer utilizes DAQ occurances and events.
You may want to look into triggering, timed loops for real-time applications. Let us know if you have any additional questions, we'd be glad to assist you.
Sandra T.
Applications Engineer | National Instruments
05-25-2007
09:39 AM
- last edited on
05-05-2025
01:03 PM
by
Content Cleaner
05-25-2007 04:40 PM
Thank You for replies.
I have done in my application a separate thread with loop that reads DAQmx read, but it still seems to be too slow. I think one reason is that I am using two USB 6009 devices, so during every loop iteration the separate thread must read 2 times analog inputs and 2 times digital inputs. Does it means that the latency over the USB bus is 4 times longer? If it is so, is it wise to by a bigger (so I do not need 2 devices) and better USB device? What are suggestions and is there any NI-DAQmx USB device that supports timed loop?
Peeter
