Multifunction DAQ
DAQ error 10452
I am using an DAQ PCMCIA 6024E with LabVIEW 6.1 and XP operating system. This setup was sucessfully runing a test station on my HP Omnibook XE2. However, I was having problems with the hard drive, so I purchased a Gateway MX6446 to replace it.
Now the system won't accept any AI from the teststation. The AO and DI/O work, but when I test the DAQ card, "the device is not responding to the first IRQ level". The AI channels give a 10452 error.
The DAQ card is assigned IRQ 20, which is the same IRQ for the TI PCIxx12 cardbus controller. There is and TI PCIxx12 Integrated FlashMedia Controller which is assigned the same IRQ.
It appears XP will not allow IRQ changes (at least as far as I can find) to resolve the conflict. How can I resove this "no interrupt level available" error and get back to running my teststation?
(3,085 Views)
These two posts maybe helpful:
http://forums.ni.com/ni/board/message?board.id=250&message.id=4640&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=180&message.id=3905&requireLogin=False
Abhinav T
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,066 Views)
