05-21-2008
06:17 PM
- last edited on
10-03-2025
11:03 AM
by
Content Cleaner
-- I have the same issue as this previous post from 2005:
https://forums.ni.com/t5/Multifunction-DAQ/daq-device-emulation/m-p/184532?query.id=28253#M10113
-- We are planning to buy the NI PXI-6514 (32 Source/Sink DI, 32 Source DO). I am developing code to use the NI DAQmx to perform digital read/writes. I have a licensed version of measurement studio for Visual Studio .Net installed (version 8.1.1). We havent received the actual hardware, as it is on order from NI. I found a walkthrough that explains NI simulated DAQ devices:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0PxCAI&l=en-US
-- While I wait for the hardware, I want to be able to simply test that my C#.Net is able to do digital reads and writes to a NI DAQ device. The article above doesnt explain how this can be done after i set up my simulated DAQ device. Please help.
-- I am using the following logic to do read/writes in my software:
https://forums.ni.com/t5/Measurement-Studio-for-NET/c-simple-example/m-p/541163?query.id=78556#M5404
thanks!
05-22-2008
12:16 PM
- last edited on
10-03-2025
11:03 AM
by
Content Cleaner
Programming for a simulated device is nearly identical as programming for a real device. The function calls are exactly the same, the algorithm is exactly the same, the only difference is what input/output/timing features are supported by the simulated device.
The last section of the Developer Zone tutorial you linked outlines what these differences are [1]. Provided you don't use a feature not supported by the simulated device, your code will work. The shipping examples will work as well under the same condition.
[1] Considerations for Using NI-DAQmx Simulated Devices
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0PxCAI&l=en-US#toc3
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
