10-28-2005 09:28 AM
10-31-2005 08:26 AM
05-22-2008 03:04 AM
Hi Tom,
I tried doing the same but never get to run both change detection events.
When you quoted, "Only one change detection task may be run per board at any given time.", do you mean by module or the chassis itself?
A
05-22-2008 10:44 AM
Hi angel-
In general, the limitation is one change detection task per device. A "device" is either one PCI/PXI/PCIe/PXIe/USB DAQ board or one NI CompactDAQ chassis. This is a hardware limitation that can not be worked around in software.
Please let me know if you need more clarification. Thanks-
