Multifunction DAQ
DAQ damage
I have a computer with a DAQ 6025E installed. How do I check for damage in the DAQ 6025E card? How do I know that it is damage free? If damage, can it be repaired?
Message 1 of 15
(4,859 Views)
Run the online diagnostic program at http://www.ni.com/support/selftest/
This test is thorough enough to give you a good indication of whether the board is working or not.
Joe
Message 2 of 15
(4,847 Views)
Internet access from my workplace is difficult. I am not allowed to take the computer elsewhere. Can I run the DAQ test wiyhout usung the internet?
Message 3 of 15
(4,824 Views)
Try this VI out.
Hope this helps!!
Message 4 of 15
(4,798 Views)
My computer display has gone from 256 color to 16 color. I have sent for it repairs. Since it cannot go to 256 color my labview programs cannot run. The technician tells me that there is a virus. He might have to reformat. How can I reinstall my DAQ 6025E card. I am not able to find the necessarry CD.
Message 5 of 15
(4,776 Views)
That device is still supported with National Instruments Traditional NI-DAQ driver. You can download the driver. The only bad thing is that the files are really big. I would recommend downloading it once and burning it to a disc for later.
Here is the URL where you can download the files.
http://digital.ni.com/softlib.nsf/websearch/BEC182021CEB566C86256EEE00696562?opendocument&node=132060_US
-scraggs99
Message 6 of 15
(4,755 Views)
You can download any of our DAQ drivers from http://www.ni.com/support/daq/versions.htm.
I would also suggest using NI-DAQmx instead of Traditional NI-DAQ.
Anuj D.
Message 7 of 15
(4,745 Views)
Many VI are nissing from your code. For example callibration"e"series.vi is missing. Others are AOwaveform, AIwaveform.VI etc. How to test?
Message 8 of 15
(4,725 Views)
The VIs used come with a DAQ driver. You may need to update your DAQ driver installation and ensure you do a full install.
Anuj D.
Message 9 of 15
(4,703 Views)
My DAQ 6025E card was installed in 2002 in labview 6.0. If I install labview 7.0, will that be show all the missing VI? Should I buy a NEW DAQ 6025E card? HOW?
Message 10 of 15
(4,696 Views)
