DAQ analog output card : PXIe-4322
Hello all,
Can anyone confirm me or not if the following card, PXIe-4322, got differential outputs ?
I'm not sure to understand NI's connector datasheets with their output names AO0-; AO0+; ... A7-; A7+.
And it is not clearly explained in their datasheet.
Thank you in advance for your answer.
(2,106 Views)
Accepted by Scaling
PXIe-4322 is a 16-Bit, 8-Channel, 250 kS/s Ch-Ch Isolated PXI Analog Output module. It has channel-to-channel isolation hence it has differential outputs. If it has single-ended outputs, all channels will share the same ground and they won't be isolated.
https://tmesystems.net/
(2,058 Views)
yes, it is differential output. actually, you can simulate one device and see the pinout information.
(2,010 Views)
