‎11-02-2012 08:37 AM
Hello.
I am currently running a two analog input system and taking data over the course of an event. This event happens in the span of approximately 4 ms. Even though I set my sample rate to something above 1 kS/s, the output in Labview always shows each voltage spike occuring over 1 ms.
Does anyone know how to change these settings in Labview Express? Or could this be a sensor/DAQ issue?
‎11-05-2012 04:41 PM
Hello DanFisher,
What is the harwdare in use, have you checked the behavior of the signal in the MAX(Measurement and Automation Explorer) test panels? Is my understanding correctly if I say that you are seeing the spikes even though they are actually not happening?
Eric NI
‎11-05-2012 05:05 PM
I am using 2 OMRON photoelectric sensor. They output a DC votage of approx. 1.4 V when idle and 6 V when triggered. No matter what sample rate I set the DAQ to, both the triggered event and the changes in the noise all occur over 1 ms intervals. That is the "slope" of the graph occurs over a 1 ms span. By setting the sampling rate higher, I should be able to see changes every .5 ms, however, this is not the case.
I hope this was a better description of my issue.
‎11-06-2012 04:05 PM
Hi DanFisher,
Can you post an screenshot of the acquisition part of your program? That would help clear things up.
Eric NI
