Multifunction DAQ
DAQ Assistant is not in LabView
Hi all,
I use NI cDAQ 9174 and NI 9203.  I have already installed the driver for the NI cDAQ 9174 which is NI-DAQmx 9.8.0.  I can see the device when I open NI MAX. However, when I open LabView 2015, I can't find DAQ Assistant in the Function Palette. I noticed that on the chassis the "ACTIVE" indicator light is not on whereas two other light "POWER" and "READY" is on.  I did look at in the NI forums but I can't find the solution.
Any suggestion, please help !!!!
Thanks!
(3,273 Views)
Accepted by tritran
DAQmx 9.8 is not compatible with LabVIEW 2015.  You need to use at least DAQmx 15.0.  See here for more details: NI-DAQmx and LabVIEW Compatibility
(3,249 Views)
Thanks crossrulz!  It works fine now.
(3,238 Views)
