03-17-2015 04:52 PM - edited 03-17-2015 04:53 PM
how can I make a recording an analog input in first .tdms file (for example in 1 second) followed by a recording in another file (for example in 1 second)?
03-17-2015 08:16 PM
The simplest would be to configure the DAQmx Streaming feature to write your analog reads to a TDMS file. You can use a DAQmx Read property node to set the number of samples to put into each TDMS file. A new file will automagically be created once that number of samples have been streamed.
