Multifunction DAQ
Creating single executible with global variables
I am trying to create an executible with global variables. I dynamically load the source file but when I run the indicator does not update unless I run both VI's together. Is the executible require different inputs during creation?
(2,762 Views)
It's not the fact that you are creating an executable that is causing the issue. What you are experiencing is expected behavior. Please see this KnowledgeBase" for some solutions.
Nicholas C
Applications Engineering
(2,762 Views)
