Cost effective lab Temp & RH logging system
We need to log temp\RH throughout our lab in several areas.
Before we buy one of these systems from Vaisala or Omega, is there cost-effective NI hardware to accomplish this task?
A simple one room system is no problem but we have other locations in the building and need to log all locations to one data store etc.
I found some cheap 3rd party ethernet devices that I might use with WIFI but wanted to ask the community to try and keep it NI.
(742 Views)
All NI hardware require a host system to work, unless you're ready to invest in a computer per location, it is better to go with WiFi connected sensors that you can query over network.
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
(728 Views)
Are there preferred wifi \ ethernet devices to be used when using LabVIEW as the programming environment?
We don't want to buy a cDaq mainframe with comm, temp, rh modules for each location etc
(710 Views)
Not really, as long as those sensors provide some sort of API for other language or specify the protocol, it should be possible to use/reimplement them in LabVIEW.
Santhosh
(704 Views)
ok at first I thought MAYBE we could use a NI cDAQ-9191 with one module but its discontinued 😛
Thanks for the feedback.
(701 Views)
