Multifunction DAQ
Controlling two myDAQ devices simultaneously with one PC (Either DAQ assistant or DAQmx)
I want to acquire 4 analog signals for which i plan to use two myDAQ devices at the same time. I want to know how can I Control two myDAQ devices simultaneously with one PC (Either DAQ assistant or DAQmx).
(2,617 Views)
(2,638 Views)
You must use two separate tasks for the two myDAQ. You can use two instances of DAQmx assistant or duplicate the shipping example.
https://tmesystems.net/
(2,592 Views)
Duplicated with Controlling two myDAQ devices simultaneously with one PC (Either DAQ assistant or DAQmx)
(2,588 Views)
Hi, I am also facing the same problem, Can you hlep me out how you solved this problem.
(2,461 Views)
