Multifunction DAQ
Configure DAQ6259 for RSE
How do you configure (all channels of) a DAQ (PXI6259) for RSE??  I tried MAX but as soon as I get out it goes back to differential.  The bizzar thing is some are Differential and some are NRSE.  I would think they would come thru all in one format.
(3,300 Views)
Hello Clint,
You set the input configuration of your PXI-6259 when you create the task.  The input configuration input on the DAQmx Create Channel VI sets the input configuration for all channels in the task.  If you don't set this then it will use the default value which is differential for the PXI-6259.
Have a great day!
Cheers,
Brooks
(3,284 Views)
Thanks !  I was just using the (I/O)  drop down in the VIs and wanted to get away from creating tasks for each channel.
Clint
(3,268 Views)
