04-09-2008 01:47 PM
04-10-2008 02:02 PM
Hello Clint,
You set the input configuration of your PXI-6259 when you create the task. The input configuration input on the DAQmx Create Channel VI sets the input configuration for all channels in the task. If you don't set this then it will use the default value which is differential for the PXI-6259.
Have a great day!
Cheers,
04-11-2008 05:07 AM
