05-20-2014 04:05 AM
08-14-2019 05:48 PM
Hi dear Nryk.
I´m having the same problem now.
I want to ask you if you could solved this topic.
Best regards
Alvaro
08-15-2019 11:43 PM
Alvaro,
You should start another thread for your problems, but let me briefly answer by saying that if your MEMS sensor requires excitation voltage, and you don't have any outside charge amplifier that connects with the sensor and converts the sensor value to ±10V, you should use NI 9234 or others depending on the excitation the sensor requires.
Use this article to help find the correct excitation you need.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8uwSAC&l=en-US
If the power is already provided to the sensor via another amp and the sensor value is already converted to proper ±5 or 10V voltage, then you can use NI 9215.
09-10-2019 02:40 PM
Thanks for your answer friend.
