Multifunction DAQ
Reading BPW34 with PCI-6251 and BNC 2110
I am having some troubles reading a BPW34 with a with PCI-6251 and BNC 2110. I connected the diode directly to the BNC board AI0 connector and I am monitoring the signal with LabView. However, the signal is not as smooth as the one I see when I connect the the diode directly to an oscilloscope. How can I improve the reading on the NI board? Should I amplify the photodiode?
(1,646 Views)
Hi gibbsphe,
You mentioned BPW34 was directly connected to AI0, which slot did BPW34's negative connected to? Did you select corresponding terminal configuration in "DAQmx create channel"?
I would suggest you choose differential configuration, and AI0/AI8 would be differential +/- inputs (AI1/AI9, AI2/AI10 and so on).
Regards
(1,582 Views)
