Multifunction DAQ
Comunication problem NI 9472
Hello
I had my labview 2010 comunicating with some valves. My problem was that my computer had to be replaced and the so I could save my work and downgrade it with Labview 2012 to labview 8.5 (because my university now only has this version license).
So I have this program that was working before (its not mine im just using it) and now its not.
I downloaded what I think to be all the software needed with compatible versions -> labview 8.5 , DAQmx 9.3 , NI VISA 5.0.3, NI 488.2
now I just have an yellow exclamation mark in the MEASUREMENT and AUTOMATION , DEVICE AND INTERFACES
im using a card NI 9472 and USB NI 9162
I know im being really vague here but please tell me any data you need
when I select the yellow exclamation mark it gives me a message :  "you are currently using a USB DAQ device on Windows XP please visit NI.com and enter USBHOTFIX"
(3,671 Views)
Accepted by chimpymaster
Hi Chimpymaster,
Can you make a screenshot of the message encountered when you open MAX?
By the way, are you working on Windows XP?
Thank you.
Celine
National Instruments France
(3,660 Views)
thank you very much for the interest 🙂
I found the solution with the help of a friend. It seems like that when I converted the program from Labview 2012 to Labview 8.5 I lost the DAQmx connections between the valves and the Labview program
I just had to creat new virtual channels again 🙂
thanks anyway 🙂
(3,653 Views)
Hi Chimpymaster,
That's good to hear !
Celine
(3,649 Views)
