annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Chromatography Data Handling
Hello, I do alot of hplc and need to be able to do some statistical analysis of the data. For those of you not familiar with hplc, I basically get a signal(V) vs time data. Specifically I need a program that can straighten drifting baselines and determine the first and second statistical moments of a single peak from the data file. I really would like to use an exponentially modified guassian curve fitting algorithim to find the first and second statistical moments because my data always has a non guassian tail of the peak. Any help would be greatly appreciated.
Corey
Messaggio 1 di 2
3.090Visualizzazioni
Corey,
What version of LV do you have available?...the newest version, 7.1, has new analysis features included. Also, is there an online resource where I could get more information about the calculations you are trying to do? With this information, I may be able to better find pre-built code...if it exists.
-Brett
Messaggio 2 di 2
3.076Visualizzazioni
