Multifunction DAQ
Can i read from different devices simultaneously
Hello.
I have this question. Can i read from different devices simultaneously, with one DAQmxRead.vi?
thanks.
(2,855 Views)
hi,
technically one ai read will service only one at task and hence you cannot read from more than one device using one ai DAQMx read,
but for a finite acquisition,a logic can be realised where you can put two task in's from two device configurations into an array and use a 'For loop' with a single ai read funtion inside it.
Indexing the two tasks from the array one by one and reading them will do what you want to achieve.
canu plz tell why u want to read from 2 devices using 1 ai read when you can use 2 of them?
regards
dev
(2,827 Views)
