‎10-18-2005 07:40 PM
‎10-19-2005 01:47 PM
Dear Idbeu,
For fast frequency measurements and wide ranges of frequencies, you want to use two counters to get an accurate frequency. One counter is used to divide down the frequency and the other counter is used to measure it.
For slower frequency measurement, you want to use only one counter. You use this counter to measure the period and then take the reciprocal to get the frequency.
In DAQmx this is really easy because the examples specifically say this. However, LabVIEW 6.1 only works with Traditional (Legacy) DAQ. Traditional (Legacy) DAQ only has one frequency example (Measure Frequency). If you look at the description, it uses two counters for this measurement. There is a Measure Period that only uses one counter. I recommend using this VI and then taking the reciprocal.
Have a great day!
Marni S.
‎10-20-2005 10:14 AM - edited ‎10-20-2005 10:14 AM
Message Edited by idbeu on 10-20-2005 10:17 AM
‎10-20-2005 08:50 PM
‎10-21-2005 10:15 AM
Dear Idbeu,
It sounds like you are getting noise on your encoder signal. I would analyze the frequency of the noise and create a filter that gets rid of the noise. Have a great day!
Sincerely,
Marni S.
