Multifunction DAQ
Can hardware run the count direction of Counter 0 or 1 on the PCI-MIO-16XE-10?
I am attempting to perform quadrature decoding of a rotary encoder equipped with A, B, Z, ~A, ~B, and ~Z signals into my PCI-MIO-16XE-10 Board and I am confused by apparently contradictory information on the NI Website.
I have learned through the website that my PCI-MIO-16XE-10 board is identical to the NI-6030E board.
One location of the NI Website, indicates that ALL E SERIES boards are capable of control of the Up/Down signal of Counter 0 and Counter 1 via P0.6 and P0.7 respectively.  I find no evidence of this in the User Manual for the NI-6030E which I downloaded, and yet some hardware that I inherited indicates this may be possible. I deduced this from the way it was wired, the A signal into P0.6 connector and the B signal into Counter 0 Source connection.
One of the discussions states that E SERIES boards are NOT capable of Quadrature decoding.
Which is true? If this board is capable of having the Up/Down signal controlled by hardware, where is this documented? Also, if the Up/Down signal is controlled by hardware, is there some reason it cannot be used for Quadrature decoding?
I would appreciate any comments that might put me on the right trail. Thank you in advance.
(2,710 Views)
This is a duplicate post.  See the real thread here.
Have a great day!
Travis W
(2,701 Views)
