Can Matlab be used to read TDM (technical data management) files?
I run your example code , but have problems
some code like this:
tdmfile = 't.tdms';
pfile = libpointer('int32Ptr', 0);
if calllib('nilibddc','DDC_OpenFileEx', tdmfile, 'TDMS', 1, pfile) ~= 0
    disp ('TDM-file could not be loaded!');
end
plen = libpointer('uint32Ptr', 0);
calllib('nilibddc', 'DDC_GetFileStringPropertyLength', pfile.Value, 'name', plen);
when matlab run to last line ,returns
-6206 which means DDC_InvalidFileHandle
can you  help me ?thanks!
帖子被iBiR在05-05-2008 07:18 AM时编辑过了
Message 11 of 18
(2,146 Views)
Can you please tell which version of Matlab you are using.
Message 12 of 18
(2,135 Views)
I have tested it under both matlab 2007a ang matlab 2008a.they all have same problem
Message 13 of 18
(2,122 Views)
tdmfile = 't.tdms';
when matlab run to this line ,returns
0 which means success
end
but when matlab run to last line ,returns
how can I fix the problem?thanks
using matlab R2007a
Message 14 of 18
(2,105 Views)
I am trying to extract furtther information from a tdm file like the data type of a channel and the actual data itself. However, I get an error stating a pointer mismatch. I am using the statements:
ptype=libpointer('voidPtr',uint8(0));
calllib('nilibddc','DDC_GetDataType',pchans.Value(1),ptype);
to get info about the first of 7 channels. The function DDC_GetDataType returns an numerated data type (DDCDataType). Could someone please advise? Can anyone maybe direct me to an example for this?
SVJ
P.S: Extensive Googling has also failed to solve the problem.
Message 15 of 18
(1,989 Views)
it might be that the ptype should be declared as:
ptype = libpointer('int32Ptr', 0);
Message 16 of 18
(1,984 Views)
Hello Stefan
Many Thanks. I have tried that too. Unfortunately that does not work. Also, I did not mention it previously but I am using R14 SP3.
Message 17 of 18
(1,980 Views)
For anyone who is interested, this discussion has been continued here.
Chris M
Message 18 of 18
(1,933 Views)
