Multifunction DAQ
Can I use the USB-6002 DAQ to generate a pwm signals?
Yes. Actually I got a response from the NI support in Germany and they sent me the table that I attached here. It's a list of NI modules recommended for PWM generation.
About the software PWM generation, what do you understand by "low frequency"? How much is low?
Thanks for your help.
Message 11 of 13
(1,784 Views)
I think the PWM signal by software behabiour is unpredictable because depends on the tasks you're running in your system which introduce a lot of JITTER.
You don´t have repeatibility. I think I would be confortable with PWM signals generated by software around 1 Hz.
Message 12 of 13
(1,782 Views)
True, I'd only use software-generated PWM for hardware that will not break and does not control crucial applications. For dimming an LED it's find, for dimming a lightbulb that will burn if at "1" for a second or so, I would not use it.
About the rate there is also another limitation: The standard windows times has a resolution of 1ms. Implementing a PWM much faster than 50Hz does not make much sense.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 13 of 13
(1,767 Views)
