Multifunction DAQ
CB68LP
Hi
Last time, you said I don't need to connect bias resistor from  AI+ to AIGND. Right now, I would like to make sure with you or somebody that wheather I need to put another wire from AI+ to AIGND. See attached.
If the ansewer is no, I don't ned to put any wire from AI+ to AIGND. why? That way the postive current can not flow to the AIGND. I don't understand. Could you please explain?
I am in a very urgent. I need to have a quick response.
Message Edited by Support on 12-01-2005 02:53 PM
(3,850 Views)
Sorry, I miss sth. If the bias resistors are 9.8kohm,9.9kohm or 100.1kohm, 101kohm or 102kohm. Is that fine.
(3,846 Views)
