Multifunction DAQ
Audio DAQ - Latency ?
Hi all,
For an audio application, I need to apply some IIR filtering on my signal. However, I need this to be done with a very small latency (<50us including ADC and DAC).
Do you think that there is any way to do this with a DAQ board and LabVIEW ? I believe that using Windows will be a problem for reaching this kind of latency. Any other solution ?
Alexandre
(2,978 Views)
maybe it is possible with a DSP DAQ board
But I pretty shure that you can do it with a FPGA board 😉
Alternative use a blackfin or other DSP DEMO boards
Greetings from Germany
Henrik
LV since v3.1
(2,971 Views)
