Are there any differences in the base C APIs accross the version of NI-DAQ?
I need to know, apart from supporting new functions, are there any differences (name changes, function prototype changes)
in the NI-DAQ 5.0 and current NIDAQmx C APIs?
Thanks for your help.
Boniface
Message 1 of 10
(4,279 Views)
NI-DAQ 5.0 was Traditional DAQ.  If you are going to be upgrading to DAQmx then yes there are numerous changes in the API between Traditional DAQ and DAQmx.  If you really mean you are going from Traditional DAQ 5.0 to Traditional DAQ 7.x then no there shouldn't be too many changes.
StuartG
Message 2 of 10
(4,267 Views)
Thanks StuartG,
So is there a document that can provide me with details of the changes?
For example I need a document which will specify how, for example, functions like
        AI_Configure (deviceNumber, chan, inputMode, inputRange, polarity, driveAIS)
        Configure_HW_Analog_Trigger (deviceNumber, onOrOff, lowValue, highValue, mode, trigSource)
         DAQ_Clear (deviceNumber)
        etc
have changed.
Message 3 of 10
(4,259 Views)
Hello bmuser,
When you install the latest version of the NI-DAQmx driver, documentation for the function calls will be installed under Start > All Programs > National Instruments > NI-DAQ > NI-DAQmx C Reference Help.  This is your best reference tool for using the NI-DAQmx C API.  There is a similar document titled Traditional NI-DAQ Function Reference Help installed in the same location that can be used to compare the differences between the NI-DAQmx and Traditional NI-DAQ function calls.
In addition, the following Developer Zone tutorials might also be helpful:
Using NI-DAQmx in Text Based Programming Environments
NI-DAQ C to NI-DAQmx Terminal Names Translation Guide
Using NI-DAQmx in LabWindows/CVI
I hope this helps,
Travis G.
Applications Engineering
www.ni.com/support
Message 4 of 10
(4,251 Views)
To follow up what Travis said I would also encourage you to look at the examples.  My guess is there is a shipping example which will do something very similar to what you are trying to do
StuartG
Message 5 of 10
(4,238 Views)
Thanks Stuart and Travis. I have seen most of these documents including the C API Reference Help, but it is not clear to me how to take a piece of code written in ANSI C and port it to NI-DAQmx. I have
tried to match the APIs to avail.
For example in Traditional NI-DAQ, for "Analog Input" - the following APIs can be employed:
               AI_Change_Parameter
               AI_Check
               AI_Clear
               AI_Configure
               AI_Mux_Config
               AI_Read
               AI_Setup
               AI_VRead
               AI_VScale
               //Double Buffer - DAQ
               DAQ_DB_Config
               DAQ_DB_HalfReady
               DAQ_DB_Transfer
               //High level
Can someone tell me, which NI-DAQmx function(s) can be used in place of these functions - something similar to the "NI-DAQ C to NI-DAQmx Terminal Names Translation Guide"  that matches functions on both ends.
Thanks for your assistance.
Message 6 of 10
(4,190 Views)
To my knowledge there is not.  My suggestion is that it is going to be much easier for you to define what you want to do and then find an example that does this.  It looks like for the most part what you want to do is take a continuous voltage acquisition.  There is an example which shows how to do this.  Then you can get into more complicated things.  For instance, it looks like you might be configuring the FIFO transfer conditions.  This can be done with some of the more advanced properties.  If there is something specific you are trying to do let me know and I can try and best match-up what you need.
STuartG
Message 7 of 10
(4,163 Views)
Thanks Stuart,
The problem is that when do a search I see only VI examples. Where can I find only C examples?
It's real awkward that one has to look for examples instead of APIs.
Message 8 of 10
(4,156 Views)
Hello bmuser,
The DAQmx ANSI C shipping examples are installed under C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C.  For a basic finite or continuous analog input acquisition program, I would recommend taking a look at the examples titled Acq-Int Clk.c (finite example) and Cont Acq-Int Clk.c (continuous example).
Travis G.
www.ni.com/support
Message 9 of 10
(4,149 Views)
bmuser
Look at the API all you want.  My personal taste is that I can find a solution quicker by looking at an example, but if you can do it faster by looking at an API then by all means do.  You originally wanted a mapping of Trad DAQ to DAQmx which we don't have (to my knowledge), so I thought examples would be the easiest place to get you started.  If it is the API you prefer then I suggest looking at the C API reference manual.  You can find it at Start>>National Instruments>>NI-DAQmx C Reference Help.
Enjoy
StuartG
Message 10 of 10
(4,134 Views)
