I am trying to get a laptop (Toshiba Satellite 1100-S101, 1.33 GHz Celeron, 256 MB RAM) to do buffered event counting using a DAQCard-6062E. My measurement parameters using GPCTR0 include a TTL signal coming in on the source pin at a variable frequency between 0-1MHz, and a TTL-like signal on the gate pin (waveform from ACH0) telling the counter to dump into the buffer at 1-10 kHz, usually 2 kHz. The gate signal is set before and remains consant during the measurement. I am using finite buffered counting. I do this for 40-70ms out of every 100ms for up to a minute or more, so I have finite buffer sizes ranging from 40 (40 ms at 1 kHz) to 700 (70 ms at 10 kHz). I think I am forced to use interrupts because of it being a 6062E.
Is this too taxing for the laptop and/or 6062E card, because I keep getting the diabolical error -10920?
I have looked at a few knowledgebase articles, particularly 2C69GDQO (http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/db428a46f345da4986256aa100556876?OpenDocument), and it seems to me they discuss the rates at which a fairly old computer can make buffer writes using DMA or interrupts. The DAQ-STC source pin should be able count TTL pulses at up to 20 MHz, right? and if that 550 MHz PIII is getting 2-3 kHz of buffer writes using interrupts, then why am I getting error -10920 when I try to do it at 2kHz using a faster computer?
Hope you can help, and thanks.
~Dave
