I'm a bit confused on the AO capability of the PCI NI4461 24-Bit, 204.8 kS/s board. The data sheet says that the output ranges are +/-100mV to 10V.
My Measurement & Automation Explorer's Test Panel settings :
DC Voltage
Max/Min Outputs setting +/-10V
Pseudodifferential (though I see the same thing with Differential)
Update Rate 20000
The output voltage seems linear between +/- 1.0V. But then after about +/-1.20V, the output voltage doesn't seem to get any larger. My output voltage seems to be maxing out at +/-1.2V even though my range is +/-10V. M&A Explorer lets me send 10V, but I don't see a difference in the output.
I'm using a cap probe to measure the response of a part which moves linearly with voltage/current. I'm also measuring the current output from the 4461 board using a current prober. I have pretty good confidence that these two sensors are configured correctly as they are used with the 4551 board with no problem.
Help!
Thanks in advance,
Nia
