Multifunction DAQ
Analog output of PCI6025E not working
I have been doing measurements with my daq card succesfully. When i started to do measurements this morning, i had an output signal of 0.15 V on analog ouput 1 and 8.9 V on analog output 2. I tried to run the labview program, but the values did not change at all.
(2,673 Views)
The best way to troubleshoot a hardware problem such as this, is with the Measurement & Automation Explorer (MAX). Once MAX is open, go to "Devices and Interfaces". Right click on your DAQ card (PCI-6025E) and select "Test Panel". Now, select the Analog Output tab, set an output voltage and then press "Update Channel". Also, consult your User Manual to make sure that you are connected to the correct pins i.e. DAQ0OUT and AOGND.
Brian Anderson
(2,673 Views)
