08-29-2007 08:44 AM
08-30-2007
12:50 AM
- last edited on
08-04-2025
10:09 AM
by
Content Cleaner
Hi Andrew,
What is the kind of "Warning light" that you want to ON using your AO channel??
For Ex: Is it an LED??
You got the connnecting part right, but more importantly you should first confirm if your AO channel can power/drive this Light source
This shall avoid damaging your AO channel
You can find the user manual for your DAQ device, here
Read through it and confirm if the device that you connect to your AO channel is compatible with the AO channel's Sourcing capabilities
( PS: if you plan to use an LED, consider using one of your onboard DO channels)
08-30-2007
12:50 AM
- last edited on
08-04-2025
10:09 AM
by
Content Cleaner
Hi Andrew,
08-30-2007 04:39 AM
08-30-2007 04:57 AM
08-30-2007 05:13 AM
08-30-2007 10:23 AM
Andrew:
I think you missed the point that devchander was trying to make about drive capabilites.
The analog output may have enough voltage to match the rating of your light, but you also need to consider how much current (Amps) the light needs to draw in order to work.
I think the 6024 analog outputs are limited to 0.010 Amps (a.k.a. 10 milliamps). The spec should be in the manual. If your light draws more than this, it may damage the DAQ card or cause its programmed voltage output to drop.
So I advise that you check the current specification on your lamp.
-AK2DM
