Multifunction DAQ
Add global rtd channels to a new task with current global channels
I am trying to add global rtd channels to a new task with global current channels. The rtd channels work when tested but they will not show up in the task.
(3,933 Views)
I am assuming you are doing this in Measurement & Automation Explorer.  I have attached screenshots of how I added a global channel to a DAQmx task in MAX.  Please try these steps and see if that works for you.  If not please reply back with what version of DAQmx and Measurement & Automation Explorer you are using.
In the Task press the '+' button and select thermocouple.
Goto the Virtual Channel tab and select the channel you would like to add
It should now appear in the DAQmx Task channel list
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(3,900 Views)
I just realized you did this with RTDs not thermocouples.  I just did the same thing with RTDs and got the same results.
Doug Farrell
(3,898 Views)
Doug,
Yes I was trying to do this in Measurement & Automation Explore. The same way you have explained. When I would select the virtual channel it would not show in the task. I downloaded the lasted version of DAQMX, 2009 and this fix the problem.
(3,896 Views)
Great success! Glad you got up and running.
Doug Farrell
(3,883 Views)
