12-23-2009 07:51 AM
12-28-2009 01:16 PM
I am assuming you are doing this in Measurement & Automation Explorer. I have attached screenshots of how I added a global channel to a DAQmx task in MAX. Please try these steps and see if that works for you. If not please reply back with what version of DAQmx and Measurement & Automation Explorer you are using.
In the Task press the '+' button and select thermocouple.
Goto the Virtual Channel tab and select the channel you would like to add
It should now appear in the DAQmx Task channel list
12-28-2009 01:20 PM
12-28-2009 01:33 PM
Doug,
Yes I was trying to do this in Measurement & Automation Explore. The same way you have explained. When I would select the virtual channel it would not show in the task. I downloaded the lasted version of DAQMX, 2009 and this fix the problem.
12-29-2009 09:16 AM
