Multifunction DAQ
Add channel programmatically to CWAI control.
I need to add channels to a CWAI control when needed without using MAX. Some of the channels will be Differential and some will be RSE. In other words, is it possible to programmatically add channels, 0,1,2,3,4,5,6,7,9,13,14 in that order or to add a single channel that is out of sequence?
Message 1 of 1
(2,543 Views)
