Multifunction DAQ
9191 w/ ad hoc link , cannot see module after host restart
I have a cDAQ 9191 and a  9219 module,  a laptop as host,  use Ad Hoc wireless network. Everything is OK,  MAX can connect to the chaise and module,  run test-panel to module.
The problem is each time after power off the  laptop then on, MAX can only see the chaise but cannot see the 9219 module in that chaise , all operations to the chaise is all right,  just cannot use the module.   It must reset or self-test the 9191 chaise via MAX, the module then come back.
The laptop OS is Windows XP,  there is only one chaise and one host.
I don't want to reset or self-test chaise each time after power on. How to solve this problem?
Thanks a lot for any advises.
Lin
Message 1 of 1
(3,657 Views)
