02-03-2013 12:23 PM
Is it possible to wire a digital line into the AI_SENSE. That is wire PO.1 into AI_SENSE.
I ask because I need to Verify the levels for a control line on a DUT that is capable of producing +12V(+/-0.5V), +5V(+/0.1V), 0V and High Impedance (Hi-Z).
I was planning on wiring the PO.1 to AI_SENSE and use the AI_0 to measure the signal in NSRE mode to measure the +12V level and verify the High Impedance mode.
The NI6289 USB DAQ measure up to 10V on the AI lines and accepts upto 11V. By applying a offset on AI_SENSE I should be able to read the 12V signal with the +5V offset provided by digital IO line.
The worries I have are (1) the stability of the 5V level on the Digital line (2) do I need to put a current limiting resistor between PO.1 and AI_Sense to limit the current should the High Impedance mode switching leave the DUT control level at 0V.
Any help would be appreciated.
Solved! Go to Solution.
02-04-2013 06:30 AM
If you read the spec carefully, you will see that the 11V input is referenced to COMMON, not the AI Sense. So this won't work.
It seems like you need a voltage divider. Two 100k resistors would work well to divide the voltage in half. You can setup a DAQmx scale to account for this divider.
