Multifunction DAQ
6030E
Having trouble getting sample rate... Can I remove unused modules in the PXI/SCXI chassis in order to increase sample rate of my 6030 E DAQ card?
(2,884 Views)
If you do not have the SCXI connected to the DAQ card, then the sample rate is unaffected by the other cards. Explain in some detail what you mean by 'trouble getting sample'. It would also be helpful if you mentioned the programming language you are using and even attaching the code you've written.
(2,880 Views)
