Multifunction DAQ
5 volt output on USB-6009 not working
The 5 volt output on a USB-6009 is only outputting 0.88V (measued using both external multimeter and device's AI channel). Also, while capturing the waveform on the device's own analog input line, it drops to 0V every ~2 seconds. When testing the digital outputs, all 12 digital lines only put out 0V or 0.88V (tied to the "5V" line) and exhibit the same 0V dropout that the 5V output line shows. The digital counter doesn't work as well (assume this is tied to the 5V issue).
The analog side of the device works perfectly.
Is there any known problem that would cause this, or is the board just fried? Any suggestions on troubleshooting this issue???
Message 1 of 9
(5,276 Views)
The 6009 is powered from the PC USB power supply.  Is your computer configured to turn off the USB power? Are you using the 5V output to power something?  There is a current limit (200mA??). If you are powering something from the 6009 5V output, check the current draw.
Tom
Message 2 of 9
(5,269 Views)
All measurements were with no load. I was just doing an initial checkout of the device. The Analog Output lines on the device put out 0-5V just fine. I will try to plug it into other USB ports to see if there is any difference in the 5V output.
Message 3 of 9
(5,263 Views)
You may also want to try running it through a externally powered USB hub.
Message 4 of 9
(5,235 Views)
I tried other USB powered ports, tried using a different USB cable. Still only getting 0.88V out of the 5V output, but the Analog output still goes up to 5V just fine. Without any other ideas, it seems that the device is broken.
Message 5 of 9
(5,225 Views)
Sam_E,
If you would like to repair your device you can visit ni.com/ask to schedule a repair.
Dustin D
Message 6 of 9
(5,208 Views)
hi ,USB-6009 digital line outputs give 5vdc when I plug cable to the pc.What is the problem about digital outputs?
Message 7 of 9
(4,949 Views)
Probably nothing is wrong. When it powers up, the digital I/O defaults to inputs with a pull-up to +5V. This is all documented in the manual.
Message 8 of 9
(4,932 Views)
thanks ..
Message 9 of 9
(4,926 Views)
