Multifunction DAQ
34970A SimpleVoltScan example generates error message
I am new to LV and wanted to start with an example for Agilent/Keysight 34972A, which is available here:
http://www.keysight.com/main/editorial.jspx?ckey=1838058&id=1838058&nid=-33261.0.00&lc=eng&cc=CM
Once I started the application an error message "Error -2147221164" appeared (see "Error message 1.jpg"). After clicking Continue "Error message 2.jpg was reported.
DAQ connection is established.
Any hint what the proble is and how to solve it will be greatly appreciated.
(4,199 Views)
You incorrectly posted to the multifunction DAQ board instead of instrument control.
It looks like Keysight used some custom error code. You'll have to look at the block diagram to see where the error is being generated. Since you are using a driver from Keysight instead of the supported driver from NI, you should also contact them. I will say that I've used NI's driver successfully. What sort of connection do you have? Is the instrument visible in NI-MAX? Have you tried NI's driver? You had to go out of your way to download the one from Keysight.
(4,192 Views)
