Multifunction DAQ
+19 V at AI of PXI-6225
Hi, I have a PXI chassis in which there is a PXI-6225 board.  After doing some troubleshooting to determine why our setup was not  functioning properly, I connected the PXI-6225 board to a TBX-68 connector box.  I then measured the volatge between analog inputs 11-15 with respect to ai ground and found that this volatge is +19 V.  This should be 0 Volts and so explains why this unit is not functioning correctly.  Please let me know if this is fixable and if so how I can fix this. Thanks
(3,444 Views)
If you are measuring such a large value between channel and ai gnd, its better you contact your nearest NI tech support team
(3,441 Views)
Hi dilkgeet-
Can you please post the part number (i.e. 192227X-01, where 'X' is the revision number) for your board?
Thanks-
Tom W
(3,437 Views)
The unit right now is in the chassis so i don't have the part number accessible, but the serial number is HA4248911. Thanks
(3,430 Views)
Hello dilkgeet,
It sounds like you may need to send your device in for repair. You can call our support line at 1-866-ASK-MYNI (1-866-275-6964) to arrange this process.
Matt Anderson
Hardware Services Marketing Manager
(3,408 Views)
