Motion Control and Motor Drives
why suddenly error-70136 despite updated Firmware
Hi All,
suddenly  last week i got error-70136 from Check/Wait move .flx. the programm has worked for over 3-months error-free. am using LV8.0, NI Motion 7.4 and the following Firmware versions/Update:
Firmware Version - 68331  7.31.3003
Firmware Version - DPS  7.20.3001
Firmware Version - FPGA1  7.10.3001
Firmware Version - FPGA2  6.00.2009
could anyone pls proffer solution?
regards and thanks in advance
anyasodor gerald
(4,559 Views)
Hi Anyasodor,
the error -70136 is a timeout error. You could try to increase the timeout value for the Check/Wait move .flx to avoid this error.
Do you get this error permanently now? Otherwise it could be that you defined a timeout value that is reached very seldom, and that's why this error happened only now after 3 months.
Which Motion Board do you use?
Blase
(4,548 Views)
Hi Blase,
thanks for your reply. i've somehow tricked the flx to work and the tricking actually  agree with  what you are saying. i did it however differently.
am using NI PCI 7350. the error was permanet till 2-days ago, before my trick:-) i hope it stabilises!!
thanks once more and happy weekend
Anyasodor Gerald
(4,539 Views)
Hi Blase,
thanks for your reply. i've somehow tricked the flx to work and the tricking actually  agrees with  what you are saying. i did it however differently.
Anyasodor Gerald
Message Edited by anyasodor on 07-25-2008 04:18 PM
(4,538 Views)
I am having the same problem. Can u please tell me how u gt it tricked...
(4,106 Views)
