Hi JF,
The 7350-series motion controllers will work with Hall Effect sensors, because the 7350 supports onboard commutation.  Refer to pages 2-6 to 2-10 in the
7350 User Manual to see which digital lines to connect to the sensors.
Using this method, there is no need to route these signals elsewhere.  Why do you want to map the sensors to another port?
Brandon M.
Applications Engineer
