I am using a blend motion routine (derived from the example that ships with the board) to blend 3 sets of x-y points on two axes on a PCI-7344. The rountine works great except when I ask for movement in only the x direction or only the y direction. In both cases there can be pauses of 3 seconds or more between blend moves. If I have movement in the x and y direction, then there is never a pause. Why would this occur? For example if I am at 0,0 and the next set of points to belnd through is 100,0, then I will get a pause. However, if I the next point is 100,100, then there will be no pause. The stepper motors are being run closed loop at 10,000 steps/rev with 10,000 counts/rev on the encoders.
