Motion Control and Motor Drives
oscillator with variable frequency from 10 khz to 1 Mhz with variable duty cycle
we are using PCI 7344 and labview 7.1 . can we get the VI  for oscillator with variable frequency from 10 khz to 1 Mhz with variable duty cycle. it is going to be sqaure wave signal . We need to AND  this output with   one of the DIGITAL  OUTPUT PORT of PCI 7344 .
Regards
Sudhir Sawant
Email id :-  cruisers@vsnl.com
                   sy.sawant@gmail.com
(3,992 Views)
If levels are TTL, then use an 7408 or 74F08 AND gate.
(3,981 Views)
Sudhir,
Are you looking for a separate piece of NI Hardware to output this 10kHz to 1 MHz signal or are you trying to use the PCI-7344 to generate it?
Jason N
(3,964 Views)
